kriegalex's avatar
kriegalex
Status:
Resolved
Avoid using 3rd party VPN apps
Your routers should use built-in VPN functionalities of Windows, macOS and Android instead of using 3rd party apps. Ideally you give the informations needed by each OS and a clear step by step guide ...
