I have a MK63, mesh router. It connects my chromecast to 5ghz which is not supported by chromecast. I want to have the option to force a bandwidth per device which will solve such issues. Could you pl...
michaelkenward
Mar 29, 2021Guru - Experienced User
Suggestions does not make sense.
Devices that don't support 5 GHz will not (cannot) connect to 5 GHz. They will use 24 GHz.
My Chromecast happily connects to the wifi with a single SSID for 2.4 GHz and 5 GHz.
Sounds like Arjun06 has a problem that is best discussed in the appropriate support area.
(1) Trying to configure my Chromecast for a 5GHZ network. : Chromecast
