Passo53's avatar
Passo53
Initiate
Apr 29, 2019
Status:
New Idea
Band lock feature
Hi,
I like to be added one key issue to this router model (at least to this model): MR1100-100EUS, firmware is now NTG9x50C_12.06.03.00.
My router is now in daily use in a home network, router is installed in a fixed position now, with external MIMO antennas. Because of this fixed position, there are two possible frequency areas in our mobile network, 800 Mhz and 1800 MHz. 800 Mhz is in the nearest tower and 1800 MHz (tower is 15 km away) is behind of this 800 MHz tower. So - now I need the band lock feature of 800 MHz (at least) to be added to router's selection to Cellular -> Band Region.
Alternative method is to add these band lock frequencies by using Telnet commads (I'm not familiar with those :-)), so I like to have all of these band selections to be added directly to the router itself...
BR,
Pasi
Comments have been turned off for this idea
