I've been searching the forums and the Internet in general, today, as I have gotten my first notice from Comcast that, lo, I am over my 1 Terabyte limit, this month. It has been inching toward that m...
Jan 26, 2024Guru - Experienced User
FYI, the CBR40 is EoL and not being developed on any more.
You should allow others to help you in your other post before completely blaming NG. Your ISP has been making there own service modifications which may be one cause of problems. Also would need to post your modems connections and event logs there as well for review to see if there are any issues seen there.
NG doesn't provide lots of diagnostic or traffic meter options. Traffic Meter only covers over usage thru the system.
Find something that does. Though this may not help either.
Good Luck.
