I can't log out of the Nighthawk app on my phone. This needs to be fixed.
1 Comment
Comments have been turned off for this idea
That's a suggestion for fixing things, not for a new idea. So you might want to try it in the appropriate section, where people talk about the Nighthawk App.
Nighthawk App - NETGEAR Communities
If you do go there, you'll have to explain what you mean.I can exit the app with no problem. So take us through the steps you go through and where it goes wrong.
And tells us which app you mean. Android or iOS.
