Mhall98's avatar
Mhall98
Follower
Jan 19, 2019
Status:
New Idea
Circle and r9000
I have the nighthawk x10 R9000 and I would like to put “circle” on it! Circle is compatible with nighthawk x8 so why can’t I get it for my x10? You would think a higher priced item would have more options but it doesn’t. It has less options than the older models
2 Comments
Comments have been turned off for this idea
  • I have the same cuestion, Is not avilable in the Nighthawk R9000.
  • Same question... upgraded to x10 r9000 but doesn't have Circle.  Seems more like a downgrade!!  I need circle NOW!!!!
