Please add circle support. I need to be able to add schedules and control screen time etc. for my children.
9 Comments
- nigeltxNovice
This is CRITICAL feature for me
- jgaustxNovice
This feature is required and suprised that there were no options for this feature.
- JDjustJDOnlooker
I just upgraded from an older Netgear router that had circle and I am surprised and very disappointed to not have it supported on my new Orbi. I relied on Circle quite a bit. Will this be implemented at some point or do I need to return my new equipment?
- DarthNaterNovice
The parental controls on the new wifi 6 mesh systems are really bad. I agree that Circle is needed for these routers as an option as well. I upgraded expecting to have at least the same features but can't believe that good parental controls wasn't a consideration. Why am I spending so much more money to get less options? Yes, speed is important but I didn't want to go backwards with the other capabilities and functionality. Please add Circle as soon as possible!!!
- Tea01Fledgling
Same!! I upgraded to orbi AX thinking that it supports Circle. If it doesn't, I rather go back to slower speed
- gringlisNovice
Yes I bought thinking that it included Circle also, becaue we wanted a better way to restrict child usage across devices.Very disappointed that this very premium product doesn't have decent parental controls.
Add me to the list of users looking for Circle app to be natively supported on an Orbi Router RBR850. I would think a $700 product like this would have parental controls
- SlcskigirlNovice
Please add Circle!! I'm looking to upgrade to this system but if this is not part of it, I will need to look elsewhere.
- FLYS03Novice
I just bought Orbi RBK353 to upgrade from Orbi RBR20. From my point of view, the Orbi WiFi 6 model is an Orbi hardware upgrade.
However, just note that Netgear has removed the support for Circle on this new model which I think is totally unreasonable. It is literally a downgrade to me.
