paid a lot for this router and there are no partental controls, the parental control link on the router sends me to disney circle but then says it is not supported! Add circle support for this route...
michaelkenward
Jul 26, 2020Guru - Experienced User
Not so much that the developers didn't read the manual, which may have been accurate when they wrote it, but that you need to understand that parental controls and Circle are two different approaches to the same sort of thing.
Parental controls cost nothing. Circle needs a subscription. They deliver different levels of control.
You might like to research how they differ and what you can do on your router.
