axp's avatar
axp
Follower
Jun 16, 2018
Status:
New Idea
Circle support for R7800
Hi, please add the R7800 to the list of routers supported by Circle parental controls as soon as possible. Any reasons why it currently does not support Circle?
6 Comments
  • Yes please.  I bought this R7800 becasue I needed the extra USB port and thought it also supported Circle.  I need Circle worse than the extra USB becuase your native parental controls are completely inadequate if not outright nonfunctional.  Please resolve this or state you don't intend to so I can return this router for one that actually has all the advertised features!
  • I also really want this added. With three kids in the house it is a necessity. Also the current parental control app is garbage.
  • Dear Netgear,
    I am an IT in the Bar Harbor Maine area and I always USE NETGEAR routers for ALL MY CLIENTS.  I too agree with
    Motomtb2 --  the R7800 was supposed to be one of your higher end routers and the parental control that you currently have if very poor feature quality!  I aslo have children and ALL of my clients have children as well.  IF you are not going to make the R7800 compatible with Circle Disney, please come up with a firmware or 3rd party online software that will be a rich enhanced parental control that is a REAL parental control.
    Thanks AND Hope you are listening to your customers!  Respectfully,  K
  • Please add Circle of Disney asap! I bought the router because I thought it was working with Circle of Disney...
