Tonkinite's avatar
Tonkinite
Luminary
Mar 23, 2017
Status:
Unspecified
CM1000 firmware enhancement ideas
As far as the CM1000 firmware is concerned,  Netgear should consider the following enhancements:
• Log forwarding via syslog and/or email and/or secure XMPP (formerly Jabber for those unfamiliar) IM, with optional triggers.
• A throughput/traffic panel, perhaps with a realtime graphical display of activity over the past minute
• Port scan of the lower 10000 ports on the modem shows only port 80 open, which means admin passwords are sprayed over the subnet and can be seen by anyone with a packet sniffer (Android device, jailbroken iPhone, bot on on a hacked smart device). This is a security exposure and should be fixed immediately. A similar issue exists with the R9000.
Anyone else have suggestions to add?
Comments have been turned off for this idea
