I've been using the Orbi RBK50 for over a month, and I set up all my connected devices in Netgear's backend admin, with their names and device types. But I find that the selection of types and icons ...
DarkLight_72
Aug 08, 2019Novice
Paul,
I'm plenty comfortable in a linux shell (or busybox in this case) but wondering if you there was any other change you made, and or if you had to restart the web server? I'm running into some differences (because I'm on an RBR40) but paths don't line up between these two systems apparently. The images are all in /www/image/streamboost. device_type_table.json is in /etc.
If there was nothing else then I'll keep digging. I wonder if it's just the difference between the RBK50 and RBR40.
Thanks for the digging before, at least it (hopefully) will point me in the right direction.
Dave
