Bandito's avatar
Bandito
Luminary
Dec 02, 2018
Status:
New Idea
Detailed WiFi Backhaul Status for Orbi
It would be very nice to have more detail on the Orbi's WiFi backhaul status than the simple Good or Poor indication that is currently provided.  Details such as the actual connection speed and signal and noise strengths would go a long way in helping to determine the best location to place the satellites.
Also, because there is no real information about the backhaul status, when running connection speed tests you can't tell if it's the device under test's leg of the journey that may be slow or if the backhaul is the limiting factor.
I've seen other routers that at least give a signal strength for the backhual channel by showing a number of bars like a cell phone does for its connection.  Even this would be better than what we have now.
Thanks for considering this.
Comments have been turned off for this idea
