Provide a way to sort the DHCP reservation list by different fields (IP address). The way it shows up for me is based on when the entry was added. It would be more usefull if I could sort it by IP ad...
AudioHTIT
Jul 03, 2019Aspirant
This is an excellent suggestion and a necessary feature in a modern router (my Apple router from 2012 sorts by IP). Address management is key to network security and reliability, having to scroll through dozens of addresses in random order looking for a specific address is time consuming and easy to miss. If need be, allow the DHCP reservation list to be exported in order (or sorted externally by the user), cleared, and then reimported, putting it back in order.
Also reordering the list when a MAC address is edited is rediculous and compounds the problem. At least if you kept the list in the order it was entered, we could assign all the addresses up front (in IP order) using dummy MAC addresses, then later we could edit the MAC address and still have the list in order. You need some network administrators on the design team. Thanks.
