By not providing dynamic DNS support, which is a standard feature for ALL other routers/brands these days, you are greatly reducing your target audience and market share this device will appeal to. I...
MAJOR-z-BOMBASU
Oct 05, 2019Guide
OMG what a pointless discussion :D
The main idea of dynDNS integration is a kind of "ping" that updates the IP adress on dynDNS server only. There is no difference if dynDNS integration will be spawned from router or from some other device connected to internet with netgear router. In simple words all devices connected to nighthawk have the same WAN IP.
And the most important thing - dyndns integrations are not a VPN, or a kind of magic bridge that allows to pass through NAT. If you are behind the NAT, the dynDNS - even if it will be a nighthawk's feature - will not solve router's remote accessibility problem.
