I think it would be a good idea to have a built in migration assistant for moving to newer netgear routers. For instance. I have the AC1700 (I believe) router, and just moved to the newer Nighthawk...
demonic1
Oct 13, 2017Star
Not a bad idea but isn't that basically the same as this suggestion?
Unifed config file for router upgrade
And, I'm prety sure this could also be easily addressed with this fix:
Never rebuild a configuration from scratch again!
