CornishSwede
Jan 21, 2022Follower
Status:
New Idea
Enable WiFi 6 - 6 GHz Only Network (6GHz MIMO compatible) Throttle back WiFi 6E for compatibility
NB: Could not select the correct model number from list For those of us that have seemingly made the error, of buying the... Netgear Orbi AX11000 RBRE960 Quad-band mesh WiFi 6E system, (coul...
Jan 21, 2022Guru - Experienced User
You're confusing a couple things.
1. Wifi 6 is just the next verison of wifi's label. It was called wireless AX but they decided to move to a numbered system. Its not 6ghz. . Its 2.4ghz and 5ghz.
2. 6E is the inclusion of 6ghz bandwidth.
3. None of apples devices have 6ghz or wifi 6E. They do have wifi 6 but wifi 6 is only 2.4/5ghz.
4. You can't "throttle back" 6ghz because its a hardware difference.
