CornishSwede
Jan 21, 2022Follower
Status:
New Idea
Enable WiFi 6 - 6 GHz Only Network (6GHz MIMO compatible) Throttle back WiFi 6E for compatibility
NB: Could not select the correct model number from list For those of us that have seemingly made the error, of buying the... Netgear Orbi AX11000 RBRE960 Quad-band mesh WiFi 6E system, (coul...
CornishSwede
I have to admit to confusion yes...
I bought what turned out to be a faulty Orbi 850 and hurridly replaced it with a 960, obviously geting mixed up with WiFi 6 and 6GHz.
Yes I could of/should of put ax / axe
Several articles over time have mentioned 6GHz being in the iPhone 13, but as you stated, dissapointingly it appears that it is just WiFi6 5GHz
I did though read the following article that states 6E is the same hardware just new standards though.
LTCC Shortages
https://9to5mac.com/2021/11/17/advanced-wi-fi-6e-modules-iphone-14/
