CornishSwede
Jan 21, 2022Follower
Status:
New Idea
Enable WiFi 6 - 6 GHz Only Network (6GHz MIMO compatible) Throttle back WiFi 6E for compatibility
NB: Could not select the correct model number from list For those of us that have seemingly made the error, of buying the... Netgear Orbi AX11000 RBRE960 Quad-band mesh WiFi 6E system, (coul...
Jan 21, 2022Guru - Experienced User
It is pretty darned close to the exact same hardware but because of fcc requirements the broadcast rules are different with 6ghz.
Its why the RAXE500 was so quick out the gate because its basically a RAX200 that they used the 3rd band for 6ghz.
The setup for the 6ghz is just slightly different which is why it isn't just a simple firmware change.
