For security reason the radios cannot be turned on with physical button on routers like R7000 while they are scheduled to be off via user interface. However for people like me, who do not have kids bu...
JamesGL
Jun 29, 2016NETGEAR Employee Retired
Hi xalbe,
This will defeat the purpose of WiFi scheduler. Both the button and the UI option are disabled during the scheduled hours as designed. You may disable the WiFi scheduler and just turn off the wireless signal via the button if not in use and turn it on if you want to use it.
