For security reason the radios cannot be turned on with physical button on routers like R7000 while they are scheduled to be off via user interface. However for people like me, who do not have kids bu...
o-range
May 04, 2021Follower
Hello everyobdy,
i suppose there's still no rebuild of this "old" feature? As mentioned, if you have kids it's totaly reasonable that the radio button can't overwrite a fixed time schedule for on/off but there's also a use case to overwrite a schedule: For instance when you occasionally work at night (as mentioned by xalbe ) where typically the routers wifi is scheduled to off.
So please dear developer, j
just rethink this and implement and easy checkbox with a function to enable the button to overwrite the scheduler.
Cheers,
Oli
