ViperGeek
Dec 15, 2016Apprentice
Status:
Engineering Investigation
Enhancement Request: User-supplied SSL certificates for remote management
There is currently no way to install a proper PKI-chained SSL certificate from a third party like Comodo or StartCom SSL. With all current versions of the NETGEAR firmware, when enabling HTTPS acces...
cmweiss
Nov 19, 2018Aspirant
If you create the cert then you trust the cert. If you trust the cert then so will your browser. It should be an option for those who know how to use it.
