ViperGeek
Dec 15, 2016Apprentice
Status:
Engineering Investigation
Enhancement Request: User-supplied SSL certificates for remote management
There is currently no way to install a proper PKI-chained SSL certificate from a third party like Comodo or StartCom SSL. With all current versions of the NETGEAR firmware, when enabling HTTPS acces...
schumaku
Nov 19, 2018Guru - Experienced User
The feature request up here is NOT about Let's Encrypt. It's about generic CA support.
I'm fine if you want Let's Encrypt. Use search or file a dedicated feature request if there isn't one for it.
