ViperGeek
Dec 15, 2016Apprentice
Status:
Engineering Investigation
Enhancement Request: User-supplied SSL certificates for remote management
There is currently no way to install a proper PKI-chained SSL certificate from a third party like Comodo or StartCom SSL. With all current versions of the NETGEAR firmware, when enabling HTTPS acces...
dejiko
Jan 24, 2021Aspirant
Netgear always promoting their products have very high security and usually announce a lot of so called "Security Advisory" about their products, and also provide a firmware upgrade to fix the security issues. But currently, if you login to your Netgear router everytime, almost all of the internet browers saying it is insecure, with a big red label to telling you the connection has a risk for leaking your information. This issue already happened more than 4 years, is it Netgear discards their security standard and put their product with a risk forever?
As per Netgear response, you can choose to use a third party firmware to fixed the problem, but in another channel they say if you use a third party firmware it is very high risk as they cannot ensure the information safety.
As a large company or enterprises, I cannot choose such kind of insecure product, this is a very well known issue and easy to fix by adding a let's encrypt feature or upload a certificate manually. As a home user, there have many alternative product in the market already provided a solution for that. So, why we still choose Netgear?
