I'm excited to see the integration of Disneys' Circle platform in the netgear devices, but the supported devices should be larger; especially under the nighthawk brandname. I'm using the Circle device today, but in a limited capacity; only 2.4GHz band support, loss of 5GHz band use, and no inspection of wired connections. I would like to leverage this tool across all mediums and integration is the only way to acheive it without hardware changes. I'm sure both the X4S and the X8 have the resources to handle the additional workload.
2 Comments
Comments have been turned off for this idea
- rRamjetAspirant
I have the d7800 and dont konw if I should wait for Netgear to build Circle in or buy the dedicated circle hardware and turn of 5GHz as above. Need to do something for managing kids and Netgear Genie does not cut it.
- WickedTicoInitiate
I have an MR60 and desperately require this functionality! Especially with all the virtual schooling at home.
