On RAXE500, would appreciate the ability to utilize smart connect on both the main and guest network. Currently it works on the main network. On the guest network though, you need to have 3 different guest networks if you want all bands (2.4/5/6ghz) available, which seems absurd. Ideally the guest network would be able to have all bands in one utilizing smart connect.
Comments have been turned off for this idea
