momo2000
Apr 19, 2016Tutor
Status:
Declined
Feature request: Change "wan side" mac address on PR2000 when in wireless hotspot mode
I purchased the PR2000 specifically for its WIRELESS Hotspot mode (the ability to connect to another wireless network, and then create a new wireless network, with a new SSID, security and network IP...
momo2000
Sep 08, 2017Tutor
OK, it has been about 1.5 years, but glad that you have changed it to "Uncommitted Candidate" I assume that means that you are taking a closer look at it. Yep, would still like to have the feature.
