platinummonkey
Dec 01, 2017Follower
Status:
New Idea
[Feature Request] Expose Nighthawk Stats (R8000) via API
Right now the network statistics are only available via the UI and you have to jump through quite a bit of hoops to get it out, then parse the html table. Would be awesome if there was a feature to enable stats.
Ideas to add this include:
1. a JSON api endpoint specifically made to collect and report stats.
2. statsd reporter from the router (just configure a host/port)
Other stats could include # active connections, etc.
Comments have been turned off for this idea
