randomousity
Apr 14, 2018Luminary
Status:
New Idea
Feature request: provide true network segmentation for guest wifi
 It would be great if you could improve the guest wifi capabilities, at least giving the option of complete network segmentation for guest networks on your routers. Visitors, and untrusted devices (e....
schumaku
Mar 08, 2019Guru - Experienced User
Can't agree more.
Same features and proper segregation is missing on the Nighthawk, the Nighthawk Pro Gaming, and the latest Nighthawk AX Series, on Orbi and mostly on Orbi Pro. The need for proper VLAN with dedicated SSIDs is a fact today. For advanced consumers, the current guest network "isolation" (badly leaking on the MAC level) solution is not sufficient.
Unfortunately, Netgear denied these features expected by advanced home users are required. Let's try to change this.
