Hi, I've just recently purchased the Netgear Nighthawk Wifi 6 Mesh (MR60) from Costco. So far I love the setup, but I've run into a problem when trying to connect a 2.4Ghz camera system. The...
Harmon
Nov 02, 2021Novice
Most items that connect allow me to connect using AP mode or something like that. My Feit Light Cameras work but I need to get my weather station to wor. and I cannot get it to work as well. I am seriously disappointed in Netgear that you cannot turn or disable either of the networks. my old linksys could. I might go back to that and see if I can get it to work instead. using the same network name and PW. then chenging it back out. it should reconnect, but am not sure if that will work. very disappointed
