The guest network isolation is currently bad / insecure and inflexible on the Orbi family. There should be a separate dhcp / subnet for guest network with ability to allow / disallow direct traffic...
schumaku
Mar 08, 2019Guru - Experienced User
Same features and proper segregation is missing on the Nighthawk, the Nighthawk Pro Gaming, and the latest Nighthawk AX Series. By far not limited to Orbi and ref. VLAN to AP mode only. For advanced consumers, the current guest network "isolation" (badly leaking on the MAC level) solution is not sufficient.
