I just purchased a CM2050V (It wasn't listed in the suggested models above). It advertises 2.5Gbps speeds, but is shipped with a Cat5e cable. Cat5e will not support 2.5Gbps. That modem needs to be sh...
Nov 30, 2021Guru - Experienced User
I'm not sure where you looked but here's a couple just from a quick look. I can also attest to it working as my home is wired with cat 5e and I can connect at 2.5gig speeds to my CAX80, RAX200, and RAXE500.
https://en.wikipedia.org/wiki/2.5GBASE-T_and_5GBASE-T
