Make the new modem
New turbo cpu 6 core 2.40ghz or higher
New ddr4 1gb memory
Add 8 lan gigabit support 5giagit or 10gigabit
Add new channels download and upload 48x48 up and down
New modem gaming design beautiful
New led design
Fix software speed and problems
Make a new smart intelligence firewall new gen
Make a new 4 firewall protection and new smart dos and ddos and smart port scanning and new attacks ect
That protect you real time
To prevent stupid people in the xbox one or ps4 boot you from the gaming flooding you
Make a new botnet and bots protection and prevention
Make a new smart nat protection and privacy for all incompatible nat and firewall
Make a new smart download and upload chanels for the best performance and stability and low ping
Make a new frecuency start for download chanels and upload chanels to choose what chanels what to use in primary of both download and upload
Make the best modulator to modulate the best voltage and performance and stability and speed no drops ect
Make this modem support dosic 3.1 and all modulation and new modulations and frecuency and all compavility
Fix ready share problem this got connected it self with nope reason fix that the modem cold be attacked or hack
Fix frecuency problems.download channels if you set the final frecuency for example 4710000hz the modem run OK but you can feel slow performance havin the full speed fix that. I think running the fastest frecuency make the modem slow because the modem hardware is slow or cpu is slow fix that
Make a scrips protection some virus cold damage the modem because scrips are 100%vulnerable to attack or cold be modified
Add a new tech to prevent modem have errors
With speed
Dns problems
Ip
Devices
Ect
Make the modem new tech voltage real time so you can see if the signal get weaker change in real time so provider can fix it ect
Make a new cox voltage protection to prevent voltage damage the modem
Make strong capacitor
Make the best hardware gaming modem
Make a new over clock mode for ,ping or wirless or lan or cpu or memory or ect for gaming
Make a new qos gaming smart
Make a new tech for zero ping delay or lag
Make a new Dns protection
Make new anti interference wirless and signal
Make a new.protection to prevent outside signal interfere with the modem or feature
Make a new.https secure login
Make a new design login
Make a new.software gaming design
Make a new smart log log everything you made
On the modem or if some one modified the memory say it or hardware logging ect every setting
Make a smart port ward always have problems with the ports disconnect attacks ect not communicate with the ports corectly
Fix unpnp always have problems and make the device slow because the unpnp is slow and always have problems.on ports or gaming or not registered the device wtf or get disconected or speed dropping
Fix that
Make the unpnp 100% more faster that any other modem in the market
Add a new smart control device to protect from uknow conection or ports ect and new bloking sistem
Anti bypass
Anti bypass firewall
Anti bypass wirless security
Add lan protection
Add mac protection prevent a hakers clone your mac adress or use your mac on software ect
Make a new led design
Make a new update smart sistem for the modem always check for the last firmware
Make ip4 and ip 4 protection and security
Just make the ultimate master pieces modem gaming
Make 4 modem in one or 6 modem in one extreme hardware gaming
Ect thank you just helping
New ddr4 1gb memory
New led design
With speed
Dns problems
Ip
Devices
Ect
Fix that
Anti bypass
Add lan protection
1 Comment
Comments have been turned off for this idea
- William10aMaster
In place of a led a lcd screen one could read the status and have error reports on the screen for trouble shooting.
May 4gb to 8gb of ddr4 user upgradable.
