Please implement the OpenVPN client in Orbi. I would like to use a VPN connection without having to configure a VPN client on every device. There are multiple devices that benefit from a VPN but do n...
foz111
Oct 19, 2018Tutor
Running OpenVPN client would give you pretty slow VPN through speeds with the Orbi 750Mhz cpu, the cpu handles all the VPN encryption & decryption of your data, basically in layman's terms the faster cpu, the faster VPN through speeds youll get, openvpn is only currently able to use a signal core, the x4s has a 1.7Ghz cpu giving good vpn through speeds. So if i was you don't hold your breath or expect this to be implemented, if it does you'll simply be disapointed with the vpn through speeds.
