Please implement the OpenVPN client in Orbi. I would like to use a VPN connection without having to configure a VPN client on every device. There are multiple devices that benefit from a VPN but do n...
kg0
Dec 16, 2018Onlooker
Yes I would like the ability to have the vpn client at the Orbi router. Like others I was lead to believe that Orbi supported vpn client but that believe was dashed after purchase. If you do not implement at least state no vpn client in your advertising. Thank you.
Ken
