JFB04
Jan 26, 2023Follower
Status:
New Idea
Installation guide if you plan to hardwire one satellite and wirelessly connect to the other.
Is there somewhere on Netgear web site that shows/explains exactly what you need to do to set up a two satellite system, one being hardwire to the Orbi router and the 2nd one being wireless connectio...
Jan 26, 2023Guru - Experienced User
First it's recommended to wirelessly sync the RBS to the RBR, then you can plug in the RBS via ethernet connection:
