The LAN config and QoS are really crappy on Nighthawk routers. Those feature are really too primitives and should be reworked completely.The issue is that even low priority devices are sucking and d...
AbhayB
Sep 08, 2017NETGEAR Employee Retired
Status changed:
Unspecified
to Resolved
Almost all Nighthawk routers support Dynamic QoS function - it's one click enable, run the speed test, and the QoS does the rest for you: It detects the device type, application types, and even type of streaming and allocates bandwidth for the Internet automatically so a user doesn't have to do it. As the devices come online or go offline, or as someone starts streaming or gaming, the QoS algorithm will take care of it. Please see https://kb.netgear.com/25617/How-does-Dynamic-QoS-help-improve-my-Nighthawk-router-s-Internet-traffic-management.
