KarlReed
Jul 08, 2017Star
Status:
Reviewed
Limiting Bandwidth Usage by Throttling the SSID - WIFI Routers
WIFI Routers. Need to be able to Throttle Bandwith (Download & Upload Speeds) by SSID. Abilty to Select any SSID (2.4Ghx, 5Ghz, 60Ghz) and Normal SSID's and Guest SSID's and Throttle / Limit the Up...
alistairbp
Oct 20, 2017Novice
This is a brilliant idea. Our daughter is on FaceTime all the time and one of the problems now is with the new Comcast max 1TB per month. We run a business from home and therefore we’re reaching the max per month just because she’s FaceTiming. If there was a way to throttle the max bandwidth on certain SSIDs like the guest SSID then we could connect her to that one and then she wouldn’t use all our data!
