KarlReed
Jul 08, 2017Star
Status:
Reviewed
Limiting Bandwidth Usage by Throttling the SSID - WIFI Routers
WIFI Routers. Need to be able to Throttle Bandwith (Download & Upload Speeds) by SSID. Abilty to Select any SSID (2.4Ghx, 5Ghz, 60Ghz) and Normal SSID's and Guest SSID's and Throttle / Limit the Up...
mg001
Mar 12, 2018Novice
yes,this limiting needs to be a feature
ASAP
thanks
