In Australia the National Broadband Network is being rolled out and people have to connect to it or be disconnected from telecommunicatons. The major ISP insists that you use thiersuppleid router or ...
michaelkenward
Jan 28, 2018Guru - Experienced User
The feature request is asking Netgear to change the world of Access Points. It also seems to be based on some misconceptions about NBN.
But the good news is that you will not need this feature.
wrote:
The major ISP insists that you use thiersuppleid router or loose support and the phone landline.
The ability to use different hardware depends on the flavour of NBN you have.
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
Some people happily use Netgear modems and routers on NBN. The R6220 seems to be compatible with most versions of NBN.
There are plenty of discussions about NBN elsewhere in the support forums.
Nor do you need to use an AP to work with whatever NBN modem you have. Some people happily put their modem into modem only (bridge) mode and then use their R6220, or whatever device they own, as a router.
