A feature that I wasn't able to find suggested, but which I think would be great would be to utilize the backhaul wifi radios for client connections when using ethernet backhaul exclusively. It woul...
randomousity
Dec 21, 2018Luminary
OTOH, keeping the wifi backhaul even when you're using a wired one gives you redundancy, and automatic fallback if the cable is severed, rather than just an outage in part of your house.
I'd either make it a feature users can toggle on/off, or at least have them automatically re-enable the wifi backhaul if the cable loses connection.
