With an attached USB drive and ReadyShare, you are limited to individual folders with a size of 196MB. The most likely use for attached storage is to attach USB drive for backup purposes, as oppo...
c_k
Aug 26, 2021Follower
michaelkenward - thanks for your comments. I went back and forward with Netgear support several times before posting here. They believed this was a limitation. I'm interested in finding out more about your exact configuration to see if I can get this working.
The router is an AC3200. I'm using a new 5TB Seagate drive, which has a single partition formatted with exFAT. The drive works perfectly when connected direct to a desktop.
Can you please tell me more about your drives and how you were able to set these up to see all the available space?
