With an attached USB drive and ReadyShare, you are limited to individual folders with a size of 196MB. The most likely use for attached storage is to attach USB drive for backup purposes, as oppo...
michaelkenward
Aug 26, 2021Guru - Experienced User
You have asked Netgear to implement something that is already available. This is not the place to troubleshoot problems.
You would do better to take your issue to the appropriate part of this community.
Find the right place for the AC3200 (AC3200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. Look at the label on the device for the model number.)
Perhaps it is a Nighthawk router.
