With an attached USB drive and ReadyShare, you are limited to individual folders with a size of 196MB. The most likely use for attached storage is to attach USB drive for backup purposes, as oppo...
michaelkenward
Aug 26, 2021Guru - Experienced User
And I have said that it works.
Please raise this as a problem in the appropriate section.
