Junkyard_Dawg's avatar
Jul 25, 2022
Status:
New Idea
Missing Static LAN LAG on Netgear Nighthawk CAX80-NAS
The Netgear Nighthawk CAX80-NAS is missing the option for Static Link Aggregation Group (LAG) on all firmware versions. According to pages 60 – 61 of the manual, there should be a radio button to enable Static LAG, but this is not the case. Knowledgebase article 60368 from Netgear also confirms the same information that the Netgear Nighthawk CAX80-NAS cable gateway is supposed to have this feature. this feature is advertised for this device and should not be missing. It is deceptive to omit such a feature.
Also, I think the router should support some form of VPN tunneling protocol so you can establish a VPN to another location, instead of only offering VPN connections to the gateway for clients running the software.
Comments have been turned off for this idea
