I keep going over 1TB and get charged, would like to see individual device usage on ORBI
22 Comments
Comments have been turned off for this idea
its literally the most requested feature on the ideas exchange for home.
https://community.netgear.com/t5/Idea-Exchange-For-Home/Bandwidth-monitoring-by-device/idi-p/1627368
- SpammikosNovice
Please!! Devices pass data cap, may have to find an other system as it would be less expensive to buy a new router!
- PurdueRamOnlooker
I have issues where I feel one of my devices in the house is sucking up more internet than it needs. So I want to be able to tell which INDIVIDUAL device is eating the most data and put some limits or speed restrictions on it
- BrianFB51Novice
I'd just like to be able to monitor usage by device. I don't even need to limit it. But would like to see who is sucking up the bandwidth.
- mjcogginsNovice
When is the firmware release scheduled that will support Circle 2nd generation? This support parental controls and usage monitoring.
- W8ITCOnlooker
Seems like that shows time on but not the actual amount of data transfered up and down which other systems do.
- jaredbeNovice
I'm about to return my orbi and buy a google wifi since it does this. Please add this feature.
- ashishkbNovice
I keep going over 1.2 TB month after month and being charged $10 every 50GB overage. I'm sure some device is consuming more than its fair share. How can I find that out?
- Soko66Fledgling
Echo the need for the ability to monitor individual device data usage. Going over my monthly limit with Cox and have no idea as to what device is the root cause.
- micwebnetNovice
Google WiFi has this since 2016 in their app, both realtime and history from 1d upto 30d! Only way to catch bandwidth abusing client devices.
