Please redesign and offer a replacement power plug option for the Orbi RBS50Y Outdoor Satellite unit. Current, large power plug cannot be plugged into a convention outdoor weatherproof electric outlet box of any size. This limits the ability to wall mount device. Instead you must plug a power strip into an outdoor outlet which isn’t a discrete install.
2 Comments
Comments have been turned off for this idea
- shortnukeNovice
Ordered the RBS50Y last week. It looks like they did change the power supply so that it uses a normal plug with a PS "brick". Does anyone know if this brick is also rated for outdoor use? I will have to locate in an uncovered area.
Does anyone know if this brick is also rated for outdoor use?This isn't the place for questions like that. It is for product suggestions, which is what Miles267 did.
Try here:
