I recently got an MR6550 and a T-Mobile Business Internet account, and I've noticed the following issues:
- WPA doesn't accept all possible formats of passphrase, which per the spec are NVT characters (0x20-0x7e ASCII), and 8-63 characters long. I tried to clone a network that I use at home and it was rejected because it contained spaces. Spaces (0x20) are completely allowable per the spec. Fix you implementation.
- When you get into the settings for bands the first time, it doesn't show you any selection, even though the default is 5GHz. This should be visibly indicated.
- I don't want two different SSIDs for the different radio bands. Does anyone, really? Don't append "_2.4GHz" to the SSID. The SSID I entered is the one I want, not some mangling of it.
Thanks.
Comments have been turned off for this idea
