KarlReed's avatar
Jul 08, 2017
Status:
Reviewed
Multiple SSID's for WIFI Routers
Currently Netwgear WIFI Routers only have the ability to have 2 x WIFI SSID's - Main Routers SSID (2.4 Ghz & 5 Ghz) and the Guest SSID (2.4 Ghz & 5 Ghz).
Need the ability to have a minimum of 5 SSID's, there need to be selectable as to what is Main & Secondary SSID and what are Guest SSID's.
Many other WIFI Routers Support this feature as a stanard, even base line Routers.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router & other WIFI Routours
2 Comments
Comments have been turned off for this idea
  • I want to second this comment.
    I have an AD7200 and was shocked when I couldn't configure multiple SSIDs.  This is a serious feature gap.  In the consumer space there is a necessity to seperate users/devices from each other: traditional users, guests using the internet only, LAN party, IoT devices.  The usefulness of this product is greatly limited by this gap despite the best-in-class connectivity.
  • AbhayB's avatar
    AbhayB
    NETGEAR Employee Retired
    Status changed:
    Unspecified
    to
    Reviewed
