Other mesh networks such as Eero and soon Luma support hard wiring your sattelites. I think its extremely important Netgear Orbi does the same. Especially for those of us who can.
William10a
Feb 08, 2017Master
If you took a lan over power case and made it bigger added a few lan ports and put in the basic functions of r7000 router you have a router that plugs in a standard wall outlet, A few giga bit ports and maybe a few antennas if needed plus another opion would nice a router / repeater switch just select the mode needed and simple setup.
Maybe not the best idea but would around say 50 to 70 percent of most peoples needs for wifi in their home.
