Other mesh networks such as Eero and soon Luma support hard wiring your sattelites. I think its extremely important Netgear Orbi does the same. Especially for those of us who can.
peteytesting
Apr 20, 2017Hero
you misunderstand what mesh is about , even though the orbi isnt a mesh network anyway
in all cases you disconnect from one node to then reconnect to another no matter what you use
so called seamless roaming is not achieved in any case with domestic gear
to get that level of seamless roaming you need access points and a controller
orbi does not do seamless roaming , it does however do ap steering and client steering ( where the clients are compatable )
